Multisim and Ultiboard
Short Circuit on Inductor
Hi.. I have a simple query. How does Multisim behave to a short circuit? I take a DC source connected to an inductor. When I make it short, it should show me a msg like "The inductor gets burnt" or something like that. In stead, it shows a straignt line in an oscilloscope. I can't prove this thory in Multisim, "A short circuit is an accidental low-resistance connection between two nodes of an electrical circuit that are meant to be at different voltages. This results in an excessive electric current (overcurrent) limited only by the Thevenin equivalent resistance of the rest of the network and potentially causes circuit damage, overheating, fire or explosion." I shall be glad to receive the exact solution.
(10,257 Views)
Do not know if this will help, but there are components in the database in BASIC>RATED VIRTUAL. that actually simulate being "blown" by excessive current or voltage.
Another option would be to have two simulator circuits on screen at the same time. One with the fault and one without it. Hook Multisimeter/O-scopes to both circuits to demonstrate how the fault effects the voltages/currents in the circuit.
Multisim usually does not scream at you when a short occurs as most voltage sources are idea and really not affected  by shorting across them. The ideal sources can handle the current within the simulator without "blowing" so to speak. I know this isn't what happens in reality, but everyone needs to keep this in mind when designing a circuit. Always be sure of the current draw from the source and wheither the "real" source can handle it as well as well as the "real" components in that circuit.
One other point. I notice you said you were using an inductor. All of Multisim inductors are ideal and have no internal resistance. Therefore, in a DC circuit they would only be a intial impedence there as the voltage was switched from  0VDC to 12VDC and then it would act as a short anyway. They are pure reactance only and this means that only in an AC Circuit would they display resistive properties. In order to model the DC resistance of an inductor in MS you have to have a series resistor tied to it.
I agree with you that there should be some type of warning that a short is occuring in the spreadsheet or somewhere.
I hope some of my ramblings have helped here.
Message Edited by lacy on 09-02-2008 05:18 PM
Kittmaster's Component Database
http://ni.kittmaster.com
Have a Nice Day
(10,246 Views)
Thanks Lacy for the reply...
If you don't mind, I would like to discuss some more problems in Multisim with you.
I expect your support regarding this.
Mr. Sahoo.
(10,237 Views)
Accepted by topic author Satyabrata Sahoo
Hi Mr. Sohoo,
Multisim is ideal and it won't tell you if there is a short.
Tien P.
(10,156 Views)
