Multisim and Ultiboard
Routing Internal Program Error 1268
Anyone seen this?  My autorouter is working, as soon as I start messing with the settings in the option section, it makes it to 800+ nets and then crashes....what is this error????
Signature: Looking for a footprint, component, model? Might be here > http://ni.kittmaster.com
(4,022 Views)
Kittmaster,
After the error 1268, does the program shutdown, or does the autorouter just stop?  Is it repeatable?   If either of these situations is the case I recommend you start an email/phone support service request.  If you can get us the files and the settings you are using that would be best so we can troubleshoot the issue in R&D.
Please let me know the Autorouter options you've set and I'd be happy to try it on some of my larger designs to see if I see the same behavior here.
Patrick Noonan
Business Development Manager
National Instruments - Electronics Workbench Group
50 Market St. 1-A
S. Portland, ME 04106
Email: patrick.noonan@ni.com
Tel. (207) 892-9130
Fax. (207) 892-9508
(3,999 Views)
Yes it is repeatable, the files are sensitive and can not be released.  The failure is kicks out of the autorouter, but the program does not crash.  I've opened and closed the file and the error repeats.  This includes major changes to the default settings of the autorouter options.
(3,988 Views)
I have no idea what error 1268 is and I rarely use the autorouter, but just thinking about troubleshooting I'm wondering...
1. Does this happen with all designs or just one?
2. On the design that errors, do you have any new/unique footprints that you haven't run before? Some years ago I had an odd failure that was the result of a bad footprint made by an intern.
Hg
(3,974 Views)
Kittmaster,
I understand about the circuit - but rather would it be possible to get a screenshot of the Autorouter options popup (well 4 since the 1st 4 tabs apply to autorouting), so that I could try to duplicate your autorouting settings?
Patrick Noonan
50 Market St. 1-A
Tel. (207) 892-9130
Fax. (207) 892-9508
(3,971 Views)
