Multisim and Ultiboard
Resistor temperature coefficient setting
If I have a Resistor for 100Ω 1% ± 20ppm,and need to simulate. How to set the parameters of the Resistor?
(6,671 Views)
Double-click the resistor to open its properties, select the Value tab. Here you can configure tolerance, temperature coefficient, etc.
Fernando D.
(6,591 Views)
Hi, thank you for reply.
the normal resistor temperature coefficient is like 20ppm. How to select the value, just select TC2 and type number 20 into TC2?
(6,566 Views)
Accepted by topic author kimi_
TC1 = (Coefficient) (ppm/°C)
Since ppm means parts per million, then we have the following equation:
TC1 = (Coefficient) (10-6/°C)
For a temperature coefficient of 20 ppm, TC1 = 0.00002.
Fernando D.
(6,546 Views)
Thank you so much. This is very helpful.
(6,531 Views)
