Multisim and Ultiboard
Re-organizing component lists
Is there a way to re-organize the component lists?
For example, from "Sources" I pick "DC_POWER" and "GROUND" over 95% of the time, so I would like to move these two entries to the top, so I would not  need to scroll to get them.
Is there any way to do that?   If yes, how?   If no, how can I make a feature request?
(814 Views)
Hello! The easiest way is to make a template file and save it in documents. Then it will be called instantly when you open the 'yellow' folder
(800 Views)
