Multisim and Ultiboard
Pin/pad clearance
The clearance of a pin / pad have on all sides the same dimensions.
Is it possible to make a custom clearance without using the "keepin/keepout" option (because it gives me a lot more warnings).
Another problem, the clearance wont change if I replace the component (using "Parts" I select the component and search in the database for the same (updated) component) or when I use "update shapes".
To fix this I need to delete the component and place it again.
Is there a way to also update the shape of the clearance without deleting the components first?
(3,350 Views)
Accepted by topic author Lighting01
Dear Lighting01,
Thank you for your post. It is not possible different clearance sizes for the same object. You can change the part clearance on the Spreadsheet View under the Parts tab.  There is an option to set clearance with respect to a  trace and the other with other parts.
Martijn S
NI Netherlands
(3,329 Views)
