Multisim and Ultiboard
Part Symbol Rotated Text Problem
I am making a large symbol for a packaged CCD that has 68 pins. I am using text to identify the signals at each pin. I am using all four sides of a square to place the pins, and I have the text for the top and bottom sides rotated 90degrees. In the editor, the symbol looks fine. But when I place the part in my schematic, the top and bottom text are not rotated and their placement is rather garbled.
I am using Multisim/Ultiboard  13.0.
Any help would be apprciated
Rick
(3,008 Views)
Hello Rick:
Can you please share with me the files of the project that are giving you this issue?
I will try to reproduce this issue, can you please tell the procedure you follow to modify the terminals names?
Thanks for all the information.
(2,981 Views)
Attached is a schematic where I just place the part with the corrupted rotated text in question.
What is strange is that in the select component dialog box, the symbol looks fine.
When I created the symbol, all I did was to use the rotate text command for the labels along the top and bottom.
Rick
(2,978 Views)
Another tidbit. The symbol looks fine in Print Preview, so it only seems corrupted on the display.
I am using Multisim 13.0 on a Windows 7 Virtual machine under VMWare.
Rick
(2,975 Views)
