Multisim and Ultiboard
Offpage connector
Hi
Just wonder how to connect offpage connector in the same sheet. See attached file.
I want to connect V1 with offPage3, and V2 with offPage4.
If I try to rename offPage3 to V1, warning appear RefDes must be unique.
There must be some way to connect node without draw wire between components.
It get pretty messy when using many component but still to few to use multi-sheet-page.
Olan
(5,003 Views)
I don't believe you need the offpage connector.  If you remove those connectors and just rename hte net to have the same name, it should automatically connect.  Check the 'nets' tab in the spreadsheet view to make sure they are one and the same.
(4,991 Views)
that is right, it is called a net alias, and MS will warn that it will be joining the two nets together. You may want to turn ON "show nets" in the sheet properties so you can visually reference alias that are or are not connected.
OFF PAGE CONNECTOR means exactly that off to ANOTHER page/sheet in the project.
Chris
Signature: Looking for a footprint, component, model? Might be here > http://ni.kittmaster.com
(4,980 Views)
