10-24-2007 02:27 AM
When using the noise analysis to determine the noise for a potential divider consisting of two 100k resistors in series the results obtained were as expected.
When using the noise analysis to determine the noise for a potential divider consisting of a 100k resistor in series with a 200k resistor the results were not as expected (100k connected to power supply, 200k conneted to ground). We would expect the 200k resistor to have VN2 double to the 100k. It is actually shown as half. When the 200k is swapped for a 300k it is a third smaller than the noise voltage for the 100k when we would expect it to be triple. The figure for the 100k is what we expected from our hand calculations using the formula VN2 = 4KTBR.
All resistors have the same temperature and all settings on the noise analysis are default other than the bandwidth being adjusted to 1Hz - 1MHz. The input noise reference source is VV1 (the only power supply in the circuit), output node is between the two resisters and the reference node is 0.
Further inconsitancies appear when using a power supply connected to a 100k connected to a 200k connected to a 300k connected to ground. When the output node is selected between the 300k and 200k the results are all as expected but when the output node is betwwen the 100k and the 200k the results are all very strange. (or the other way around, the point is they're inconsistant)
We are not saying the figures are wrong as we have limited experience in this field and were using it as a learning exercise, but the figures are not what was expected, can this be explained? or corrected by changing the configuration/ options of the analysis?
Dan
10-24-2007 08:39 AM
10-24-2007 10:03 AM
Using VN2 = 4KTBR
Bandwidth 1-1MhZ in multisim. I just used 1 x 10^6 in my calculator but this will not effect the results in the way experienced.
Temperature = 300.15K
Output node = 1
Reference node = 0
Input noise reference spurce = vv1
Expected results:
Inoise_total_rr1 = 1.657 nV2
Inoise_total_rr2 = 3.314 nV2 (so double the noise for r1 as would be expected before even puching the figures into a calculator, in my opinion)
Inoise_total = 4.971 nV2 (noise values for r1 and r2 added together)
Onoise total = 2.209nV2 (standard potential divider calculation on sq.root of Inoise_total then squaring again to get V2 format multisim provides)
Mutlisim results:
Inoise_total_rr1 = 1.658 nV2 (as expected)
Inoise_total_rr2 = 828.787pV2 (half of r1 not the double I was expecting)
Inoise_total = 2.486nV2
Onoise total = 1.105nV2
I ran through my method of calculating using multisims individual component noise conrtibutions and came out with the same inoise and onoise totals.
Dan
10-24-2007 01:29 PM
10-25-2007 04:56 AM
Hi Dan
The tutorial that Max sent explains very well the noise analysis in SPICE, however I noticed that in Multisim the results are not as expected.
I am in contact with the EWB support with regard to the issue and I will get back to you as soon as I hear from them.
KostasB
National Instruments UK & IE
10-25-2007 05:12 AM
10-25-2007 10:49 AM
Hi Max
Just to clarify:
Output variables "onnoise_total_RES" and "innoise_total_RES" are not simply the noise source equations for the respective resistor. They refer to that noise source reflected to either the Output in case of "onnoise_total_RES" or to the Input in case of "innoise_total_RES". Therefore, the simulation results are correct.
If you want to calculate custom expressions rather that the ones already built in Multisim, you can use the Simulate>Postprocessor
after you run a simulation.
I hope that helped,
KostasB
01-14-2008 03:47 AM
01-15-2008 01:44 AM
04-08-2008 10:26 PM
I am trying to do a noise analysis just like what is shown from the noise analysis example from the help menu in multisim. I followed exactly the same process as what is shown. However, when I simulate my circuit, I do not see the noise spectral density plot as what is shown from the example. I got an empty graph with just the printed values. Can anyone help me?
Marlin
