10-01-2009 05:11 PM
Solved! Go to Solution.
10-02-2009 09:30 PM
04-09-2010 06:57 AM
I´m even more newer than you, this is my first post...
I can tell you that is not posible to see 720mVs when a pin is high and 300mV when low, i thing most be a bug form multisim...
I´m starting in MCU´s with multisim and the pin´s out doesn´t turn on too, i´m going to check your solution but i don´t think it will normal to do that...
Can you tell me if that was your final solition or you found another...
