Multisim and Ultiboard
Need help in this simulation 3phase rectifier connected to a 3 phase inverter
Hello everybody,
I am trying to simulate the connection from a rectifier + inverter group to the network to then be able to calculate the current distortion that is injected into the network.
The circuits work individually but when I try to join them and start the simulation I always get a non-convergence error!
I changed the options of the parameters ABSTOL, VNTOL and RELTOL but I still have no results.
If anyone has any idea how I could do I leave the file below.
Thank you in advance
(3,662 Views)
Hello GioMasaa,
Try to use real components with realistic properties to avoid Convergence issues.
I have modified the schematic here is the result:
__________________________________________
The best way to thank, is to give KUDOS
(2,173 Views)
