Multisim and Ultiboard
Multisim
I‘m tring to do the test with Multisim to find the relationship between PWM and the DC current.     single phase ,  inverter with IGBT,
Please to see the attachment.
but it's wrong,how to deal with?
(4,601 Views)
Seems to be a few things. You always need ground for your simulation to work, and a load coming from the source (as it is a rather high voltage source). I adjusted a few parameters under interactive simulation settings such a the precision of your circuit's tolerance (you can find this under the menu simulate, then once inside go to use custom settings under analysis options.
Kind Regards,
Miguel V
(4,560 Views)
thank for your help
(4,546 Views)
