Multisim and Ultiboard
Multisim crashes when using In Use List
If I begin a new schematic in Multisim, I can use the In Use List on the toolbar to quickly place components.However, if I open an existing schematic, rename it using "Save as.." and then attempt to use the In Use List, the program crashes. The part I select from the list does not appear on the mouse pointer and after a few moments the pointer changes to the hourglass. Then I get the typical "This program has encountered and error and must close" popup. As the program closes, I get numerous popup messages of the flavor "Instruction at "0x12345678" referenced memory at "0x12345678". The memory could not be "read"." (The hex addresses change and sometimes the memory could not be "written" instead of "read")
I am using Power Pro 9. Has anyone else had this problem?
Hg
(3,301 Views)
Hi Hg,
I just ran a quick test but couldn't reproduce the issue.
  • Does the crash happen with a specific schematic? (if yes, please attach it). Try opening one of the Multisim samples, same issue?
  • What's your operating system?
  • Multisim product version (go to Help>>About Multisim)?
Fernando D.
(3,273 Views)
