Multisim and Ultiboard
Multisim V14 Demo: Bug in Virtual Function Generator
There must be something wrong with the offset functionality of this thing...
-Feeding sine (F=50Hz, DC=50%, Amp=80Vp, Offset=0V)  into a RC (L)  lowpass filter (100K & 100uF)
-Type in a +5V offset and observe the DC shift on the scope... looks fairly OK
-Offset back to 0V
-Set F much higher, e.g. F=50Khz
-Type in the +5V offset as before... Now the the DC shift observed on the scope is moving VERY slowly, should be the same as with F=50.
Atemporary workaround (also proving the above problem) is to insert a (switchable) DC source in the generator's ground wire...The DC component out of the filter now
moves 100's of times faster, more in line with the filter's time constant & reality.
Pls. Fix.
(3,758 Views)
Solved.
Turned out (to me) that high frequency simulations take a lot of time. A Deta T measurement on the scope shows everything is working correctly, in both cases I mentioned.
(3,735 Views)
