Multisim and Ultiboard
Multisim Multimetr - problem RMS
Hi, everybody! There was a problem with measurement of RMS. Multisim's multimeters show something unclear. I assembled the module of measurement of RMS and wanted to check on devices. Indications of devices differ from a calculated value of RMS of a signal... Maybe I incorrectly do something.???
(5,528 Views)
I do not know what is in the RMS conversion module but I would be concerned about the time constant of the load circuit.  With 47 nF and 40 ohms the time constant is 1.88 microseconds. Most physical RMS converters require time constants longer than the period of the input signal.
Lynn
(5,503 Views)
The structure of the module is simple and primitive. It is collected on ideal components. I am disturbed that the multimeter 34401A (measures true RMS) has to show value 8.483. In, and shows absolutely other value. On a formula value 8.483 dismisses.
(5,493 Views)
