Multisim and Ultiboard
Multisim Error when importing JFET model
Похоже, ошибку нашёл.
Хотя это не влияет на настройку...Наверное модели выходных транзисторов надо менять...
Message 31 of 45
(2,614 Views)
I saw it too but it only relates to the symbol orientation. If you see the PINOUT the pins are mapped properly to the nets:
Kokorian has provided some interesting information:
"use only 2sj74 of other source than Toshiba. J174-j175 have gate cutoff voltage too high, it must be less than 1v. 2sj74 is less than 0.5v."
He provides two curve charts to review.
Message 32 of 45
(2,602 Views)
Схема неуправляемая. Увеличил R1, R2 до 6 Ом. Удалось достичь половины напряжения и ток в 1,2 Ампера при независимых источниках постоянного напряжения. У Кокоряна можете узнать, какие напряжения на затворах в его реальной схема?
Message 33 of 45
(2,596 Views)
Hi Tipa,
I have sent him a message but he is not responding at the moment. Did you try simulating his circuit with 2SJ74? I have not had a chance to yet but I will do it when I have some free time.
Message 34 of 45
(2,556 Views)
Hi - to be honest, I'm not inspired by this project. I have no idea how to steer the output transistors when I simulated their opening with regulated sources, and set the midpoint. He gave different signals to the shutters, but he didn’t get anything. I will study the theory about SRPP, and I will return to this topic. Everything should settle down in the brain, the answer sometimes comes by itself ...
Message 35 of 45
(2,553 Views)
нет коротких путей туда, куда стоит стремиться. Не важно, как медленно ты продвигаешься, главное, что ты не останавливаешься. Волко́в боя́ться — в лес не ходи́ть
I have 16 pcs of these devices so I hope to get a simple circuit working that can utilize them. Kokorian offered his design idea in good faith. I will try to utilize it.
SRPP is a popular topology in HIFI circles. I can refer some reference to:
http://sound-au.com/valves/preamps.html (see figure 3)
Old patent:
https://patentimages.storage.googleapis.com/84/88/29/5a49cb0708bba9/US3286189.pdf
Message 36 of 45
(2,542 Views)
Спасибо!!!
Message 37 of 45
(2,517 Views)
Message 38 of 45
(2,474 Views)
Hi Tipa,
I am working with another engineer. He helped to get it working better and found mistake with my instrument connections:
Message 39 of 45
(2,456 Views)
Hey super duper! The voltage swing on the oscilloscope is not visible - the dashboard is cut off, which is below. I see 12 volts on the voltmeter, but this is a small signal swing from a source of 50 volts. It seems that the terminal transistors are not swinging enough. I'm disappointed in this scheme...
Message 40 of 45
(2,416 Views)
