Multisim and Ultiboard
Measurement Probe Values
Can someone tell me what is the difference between V, Vrms, Vpek and Vdc values shown by measurement probe in Multism?
Regards.
(4,097 Views)
Probe voltages are as follow:
V - instantaneous voltage, if you have an AC signal this value will continuous change
Vp-p-  Peak to peak voltage
Vrms - root mean square or average
Vdc- DC voltage
Double click on the green arrow to open the probe properties dialog then select the Parameters tab, you can turn on/off to show only the information you want.
Tien P.
(4,086 Views)
