Multisim and Ultiboard
LabVIEW Instrument (lvinstrument) for Composite Video Signal Generation
I want to simulate a video amplifier (monochrome) in Multisim. For testing the amplifier I've to feed a Composite Video Signal to the input of the amplifier. I need a Composite Video Signal Generator which takes a video image file as input and generate a Composite Video Signal as output. I understand that LabVIEW instruments can be called in Multisim. By default this signal generator is not there in the 'lvinstruments' folder of my Multisim installation directory.
Has anyone used a Composite Video Signal Generator LVINSTRUMENT in Multisim? Any idea where can I get the suitable VI?
Sinoj
(3,134 Views)
Hello Sinoj,
Alot of custom simulation analyses can be found on:
http://zone.ni.com/devzone/cda/tut/p/id/13715
If you cannot find it over here, then you can also visit the following user group and search for possible instruments to use:
https://decibel.ni.com/content/groups/multisim-custom-simulation-analyses-and-instruments-powered-by...
If this group does not provide an adequate solution, then you can of course always create your own LabVIEW Instrument in LabVIEW.
Hopefully this helps you a bit further.
Kind Regards,
Thierry C - CLA, CTA - Senior R&D Engineer (Former Support Engineer) - National Instruments
If someone helped you, let them know. Mark as solved and/or give a kudo. 😉
(3,051 Views)
