Multisim and Ultiboard
取消
顯示結果
搜尋替代
您的意思是:
Interfacing of multisim 11.0.1 to labview 8.5
how to interface it
0 積分
1 條訊息(共 10 條)
5,101 檢視
You will need to use the LabVIEW Multisim Toolkit. This works with LabVIEW 8.5.1 and higher. You can download it from the link below:
https://lumen.ni.com/nicif/us/evalmultisimtlkt/content.xhtml
Here is a page explaining the toolkit and how to use it.
http://zone.ni.com/devzone/cda/tut/p/id/7785
Hope this helps.
Tayyab R,
National Instruments.
0 積分
2 條訊息(共 10 條)
5,092 檢視
sir can you please tell me...?
can i find FFT of signal ...which will be the output of a circuit designed in MULTISIM11.0.0
using LABVIEW and MULISIM interfacing????
0 積分
3 條訊息(共 10 條)
5,031 檢視
Hi Sachin,
Take a look at the article below. I think it should help with what you are trying to accomplish.
https://decibel.ni.com/content/docs/DOC-7438
Tayyab R,
0 積分
4 條訊息(共 10 條)
5,022 檢視
sir i already had multisim 11.0.1 version and i install labview 8.6 evaluation version and i also install mutisim tool kit.
then i download the both the files (you attached for me).
i run them but it gives me an error that mutisim version is not compatible. pls tell me wat should i do....
0 積分
5 條訊息(共 10 條)
4,994 檢視
sir please tell me....what should be the name given to file path in labview?? regarding mutisim file.
is it the name which is given to probe like "output or the full name of circuit eg.RLC.ms.10 in path.
0 積分
6 條訊息(共 10 條)
4,992 檢視
respected
i am getting an error no. 2147467259 with  LabVIEW: (Hex 0x80004005) Unspecified error. when i run my .VIi in labview 8.5.
NI System Configuration: (Hex 0x80004005) Miscellaneous operation failure.
when i search on google .they told it is due to window 7 (64 bit) and accesing of data base of win32 type like that....
please tell me sir what should i do...???
1.i have window 7 (64 bit) installed on my pc.
2. i installed mutisim 11.0.1.
3. i installed labview 8.5.
am also sending you the labview vi i made.
and i give "C:\Users\sachin gupta\Desktop\RLCcircuit.ms11" name in Path at front panel.
0 積分
7 條訊息(共 10 條)
4,990 檢視
respected sir,please tell me....
at starting  wheather i select file path ind or file path cntrls
for giving multisim input to labview Vi????
0 積分
8 條訊息(共 10 條)
4,989 檢視
Hi Sachin,
I'll try to answer a few of your questions.
-Multisim 11.0 should be able to run Multisim 10 files. The example file is a Multisim 10 file so if you were just to open the VI and run the simulation and select the file, it should work.
- If you create a file in version 11, it gets saved as filename.ms11 . To be able to load this file type, you will need to edit the VI to look for .ms11 files as shown in attached screen shot.
- I am not sure about the error message that you mentioned as that is a very generic error code. I would suggest that you login as administrator when you are using LabVIEW. When you run the program in Windows 7, you can right-click and select Run as Administrator. See if that resolves the issue.
Hope this helps.
Tayyab R,
0 積分
9 條訊息(共 10 條)
4,971 檢視
sir i install labview 8.6 evaluation version. but still its not working. is their any differnce between full and evaluation version....may be am getting error due to this
0 積分
10 條訊息(共 10 條)
4,959 檢視
