Multisim and Ultiboard
In the Multisim, how to use the "DIPSW2~DIPSW10" in the switch pack?
I have tried for thousands but it just don't works.However, the "SPST" and the "DIPSW1" works as expected ! How wired is that.
I simply connect it with a DC_POWER and a multimeter.
I am really confused and eager for the solution, any information will be appreciated, thank you.
If you know how to use it, I will be very appreciated if you can give a complete screen shot, because I am a novice
(7,961 Views)
Hi there,
What's your Multisim version? You can find this information in the Help>>About Multisim menu.
Fernando D.
(7,937 Views)
Thank you for repies and my version is both 13/10 or later.
I found that, in DIPSW2~10 case, when I use the single mouse-click to switch on/off, it doesn't work; However , if I use the keyboard to control, it can go very well.
In DIPSW1 and spst, single mouse-click is avaliable.
(7,935 Views)
I tested again.
In multisim 10, keyboard control is ok with the DIPSW2~10.
In multisim 13, keyboard control still doesn't work.
(7,931 Views)
anyways, int the further test, there is always bugs with 2~10 in both ver.10 and ver.13, and the result is unpredictable
(7,930 Views)
Thanks for the information, I was able to reproduce the issue. For your reference the Corrective Action Request is 426846. Our developers are aware of the issue and it should be fixed in a future software update.
Thanks again for reporting this.
Fernando D.
(7,926 Views)
