03-07-2007 04:40 PM
03-12-2007 01:51 PM
The PWL is the only signal source where you can you are able to import data generated by outside of Multisim. The data to be import must be voltage or current vs Time format. In Notepad, you can simply have two columns, in the first column and time and the other is voltage. When you import the data into Multisim, the output signal will look like you have connected the dot. If you want a square wave, you should have one additional point before the transition.
02-15-2011 02:04 AM
Hi, Tien
According to your reply, I generate one .txt file and input the data as below and define the PWL reading data from file:
02-15-2011 02:07 AM
Hi, Tien
BTW, if I directly edit the data points in the table rather than reading from file, the PWL works quite okay.
Seems the format of data file has some problem.
02-15-2011 02:40 PM
Hi Tang Lihua,
Can you post the text file you are using so I can take a look?
02-16-2011 08:11 PM
Hi, GarretF
I have solved the problem. It is due to the chinese characters in the path. I put the input data file in other place and now the simulation works.
Thanks!
02-16-2011 09:38 PM
Thanks for letting me know what the problem was. I'll enter issue this into our defect tracker so we can address this in a future release.
02-28-2011 12:07 AM
Hi guys,
Can anyone share with me the .txt file as im having problem to generate the ECG signal to test my circuit.
Thanks in advance
