Multisim and Ultiboard
I see extra data when i export the board outline of my design as a gerber file
Each time I export the gerber files of my project and use any gerber viewer to verify my design I see the following error. In the Board Outline layer, in addition to the actual board outline, one would expect to see, I see three additional points around the board. These circular markings seem to get added around my board each time I do an export using Ultiboards built in Export feature. I am attaching a snap shot of how my board outline layer looks and you can clear see the three circular spots around my board. I am also attaching my main project file for your review. Any help will be appreciated.
RD
(3,383 Views)
Accepted by topic author R_dunung
Hi
These are the fiducial markers.
If you don't want them, switch them off:
go to OPTION menu
the Global Preferences
Under the PCB design tab, you'll see a box with post processing
there you can switch off teh fiducial markers
succes!
(3,379 Views)
Thank you. Works like charm!
-RD
(3,375 Views)
