Multisim and Ultiboard
I can't get rid of layer names from the Ultiboard PCB properties-General layers tab
A bunch of DXF layer names were erroneously entered into Ultiboard 10.1 a few years ago during a DXF importing operation. I upgraded to 12.0 recently and hoped that the old layers would be eliminated. I have been wanting to get rid of them for a long time. I tried deleting the ub_config file in AppData, but it didn't remove them. Is there anything you can think of to extract them from the program's grasp? Thanks, Tod
(4,490 Views)
Accepted by topic author Todc.18
Hi Tod,
I suspect one of your design file is causing this.  If you go to Options>>PCP Properties>>General Layers, do you see the DXF layers in here?  If you see the layers, can you select it then press the Delete button?
Tien P.
(4,489 Views)
