Multisim and Ultiboard
How to plot semi log graph?
I am dealing with circuit in which resistance is automatically varying(IC AD633).I want to plot graph of Voltage against this variable resistance.Also as the  range of variation is very large I want to use semi log graph.Is it possible in Multisim? Please reply as soon as possible.
(8,818 Views)
In the Grapher View you can configure scale, range, etc. Double-click the Grapher View area to open its Properties. There, you can configure the Left/Right axis and the Top/Bottom axis. For example, you can select a Linear scale for the bottom axis and a Logarithmic scale for the left axis to create a semi-log graph.
Fernando D.
(8,754 Views)
Thank you Smiley Happy
(8,732 Views)
