Multisim and Ultiboard
How to export from multism to matlab
 I need to export signal (output of opamp ) from  multism to matlab to calculate SNR
Message 1 of 15
(11,577 Views)
Accepted by topic author fouda
Multisim doesn't export data to Matlab, but what can do is export to Excel and then use Matlab to import the Excel file.
To the export data, select View>>Grapher and in the Grapher View select Tools>>Export to Excel.
Tien P.
Message 2 of 15
(11,568 Views)
fouda,
Have you considered using the native capability of doing LabVIEW based measurements directly in the Multisim simulation rather than an external math analysis tool?  Here is a LabVIEW VI that incorporates 2 methods of calculating Signal to Noise ratio (SNR) based on posts that have been done in the LabVIEW forums.
Here are the NI links describing the 2 slighly different methods used for calculating SNR...
Method 1 -> Reference: http://zone.ni.com/devzone/cda/tut/p/id/2058
Method 2 -> Reference: https://forums.ni.com/t5/Dynamic-Signal-Acquisition/SNR-measurement-VI/m-p/224168
There are some assumptions that are built into these calculation methods, so please look through the definitions for more information.
To use, place the contents of the zip folder in the folder "C:\Program Files\National Instruments\Circuit Design Suite 11.0\lvinstruments".   Relaunch Multisim and the SNR instrument will be available from the LabVIEW drop down icon on the right (or top) of the screen for use in your own circuit simulations.
I provided 2 simple Multisim v11 examples to try.
This instrument was created with LV 2010; to use previous versions of LabVIEW instruments, check here:
https://www.ni.com/en/support/documentation/supplemental/06/ensure-compatibility-of-ni-labview-based...
For information on how to create your own Multisim VIs, check here:
http://zone.ni.com/devzone/cda/tut/p/id/5635
Enjoy!
Pat Noonan
Message 3 of 15
(11,548 Views)
Screenshots for the above Multisim LabVIEW Instrument that calculates Signal to Noise ratio...
Circuit with SNR LabVIEW VI...
SNR Instrument displaying calculated SNR.  Instrument can also display input waveform, detected fundamental signal and residual signal (noise).   The base values used in the calculations for each method are shown on the 2nd tab...  (residual noise signal is currently displayed on LabVIEW graph)...
Pat Noonan
Message 4 of 15
(11,546 Views)
Hi thanks for reply
I placed contents of SNR to directory but when I open your test example this message appears
"Cannot find the LabVIEW instrument "LVInstrIF1000/SNRv1". The following instrument(s) will not work properly:XLV1"
thanks in advance
Message 5 of 15
(11,541 Views)
fouda,
Verify that SNRv1.llb and SNRv1 folder is placed into the /lvinstruments folder - also you'll need to restart Multisim.   If this is set and it does still not work, ry the above link "Assure compatibility with LV instruments..."...
Let me know if that does or does not fix the problem.  You should see the 'SNR' instrument in the LabVIEW section as an option with the other instruments in that dropdown.
Can you check and let us know which version you are using in Multisim (v11.0, v11.0.1)?
- Pat
Message 6 of 15
(11,536 Views)
Hi ,
SNRv1.llb and SNRv1 folder exist in  the /lvinstruments folder  and when I added the files of " Assure compatibility with LV instruments" to /lvinstruments
they appeared in labview section but SNR doesn't appear ,my version is  multisim V11.0
Message 7 of 15
(11,532 Views)
fouda,
I believe you'll need the latest v11.0.1 update to get the VIs to work in the latest version of LabVIEW.
https://forums.ni.com/t5/Multisim-and-Ultiboard/Multisim-11-0-1-Now-Available/m-p/1291836
Pat
Message 8 of 15
(11,518 Views)
thanks  ,It is worked
Message 9 of 15
(11,513 Views)
fouda,
Great, let us know how it works out.  If there are any other simulation based measurement requests it is likely that they can be handled with LabVIEW.
Pat N
Message 10 of 15
(11,511 Views)
