Multisim and Ultiboard
How to define distances between layers?
How can I define the distance between each layer, por example, 10mils between top layer and second, 15mils between this second and the third and so on?
Thank you,
Rodolfo
(3,510 Views)
Hi Rodolfo,
Ultiboard doesn't have a setting for distance between the layers, if you need the layers to be a certain way, you should put it in a note on the mechanical layer and send this information to your PCB manufacturer.
Tien P.
(3,487 Views)
