Multisim and Ultiboard
How to create virtual components
Dear Multisim professionals.
I have a problem with creation of new component. The task is to create component, which will have several adjustable properties. Just like virtual components, which has Special tab on properties window, where you can specify parameters.
My research on Multisim documentation didn't reveal any way to create such type of components with custom editable properties.
I will really appreciate any advice.
(4,381 Views)
Hi StudentNI,
Currently, users do not have the ability to do this.
However, you can take an alternate path which will produce almost the same result using subcircuit parameters
Here's how you do this:
When creating a component, during the model creation stage, append to your the SPICE ".subckt" statement
"PARAMS: param1=xx param2=xx param3=xx...", where "param1" is an arbitrary name and its right hand side value is an arbitrary number
You can use these parameter names alone, or as part expressions, in your SPICE model.
For example:
.SUBCKT FOO 1 2 3 4 5 PARAMS: AV=100K VRP=1 VRN=1 RO=10 Rin=10Meg
V1     1 2 DC {VRN}
R1    100 0 {(Rin/5)+1}
B1    101 0 V = { (V(V_POS)+V(V_NEG))/2 + VRP  }
.ENDS
When you place this component on the schematic, double click it, and press "edit model", you will notice a special instance parameter text box containing the parameters you defined on the .subckt line. You can overwrite the default values for each instance of the component! This has the same effect as the virtual component with the exception of the user friendliness of tabular format.
Cheers,
Alec
Max
(4,358 Views)
Dear Maxish,
THANK YOU SO MUCH!!!
It's just what I need. At least, it will be enough for my task. You really helped me.
(4,350 Views)
