Multisim and Ultiboard
How can I get 7489 from Multisim
I have Multisim 11 in my PC, I need a IC 7489 16x4 ram for student project, but I could find it in the TTL list
(6,791 Views)
We currently do not have that model you are looking for. If you have the MCU family, you'll find some ceneric ram modules in there that you could use, otherwise, unless you can find the SPICE file for the IC you want, you won't be able to use one in Multisim.
Miguel V
(6,777 Views)
I currently don't have multisim with me, but I already found another solution. I use the first 4 input of the data select and address, the rest connect to the ground, so it function as a 7489
(6,745 Views)
it is our project to make 16x8 ram in multisim using 74LS189, can you show me the example of this? please dont use 2K8ram thank you 🙂
(6,579 Views)
(6,578 Views)
