Multisim and Ultiboard
How can I center my design on the paper in Ultiboard?
If I print my layers in Ultiboard the PCB is in the upper lefthand corner, just under the header.
How can I center the PCB on the paper?
(5,691 Views)
There is no setting that will allow you to print your board at the center of the page, the only work around is for you to place a dot at the top left corner of the board.  By doing this, Ultiboard will push you design toward the center.
If you need the fuducial marks to show on the print, export Gerber files and reimport into Ultboard be select File--Open and pick the gerber in the file of type field.
(5,683 Views)
