Multisim and Ultiboard
How Do I Create a Rounded Rectangle Hole In a Rounded Rectangle Pad for PTH Use?
I need to create a pth footprint for a ZIF connector that has a rounded rectangle plated hole through the rounded rectangle pads. I have attached a pic of my solution but I am not sure if it will translate into something manufacturable when I export to gerber. Can someone verify my solution or advise me of a solution that will work?Untitled.png
Message 1 of 8
(4,828 Views)
Would it not be better to attach a file?
Message 2 of 8
(4,779 Views)
The Ultiboard design file?
Message 3 of 8
(4,772 Views)
AUAG exactly, so that we can review it and see if it works.
Message 4 of 8
(4,769 Views)
Here is the design file but because of the DRC errors, I am unable to place traces to the pads with errors.
Message 5 of 8
(4,766 Views)
That solution works good for the pads but has round holes. I need holes to be rounded rectangles also.
Message 7 of 8
(4,755 Views)
I appreciate this was in 2017 but did you ever get an answer to your problem? I have the same one.
"Everything should be made as simple as possible but no simpler"
Message 8 of 8
(3,405 Views)
