03-16-2012 07:30 AM
Hello All,
I am developing a circuit of LED lights with LED Driver TPS92210.
My Project specifications are:
Input - 100V~245v AC
Output - 19.2V / 0.78A
Power in output for LED(6 LED's) - 15W
I am working on a circuit but I like if anyone will suggest me something regarding this circuit.
I did not find any LED Driver in multisim.Can you please help me to solve it?
Jainam Shah.
03-16-2012 12:02 PM - edited 03-16-2012 12:06 PM
You would probably be best off talking to a TI application engineer. According to the spreadsheet here, the max input range cannot be greater than 1.615 times the min input. You may be able to do something fancy with a pair of circuits and a range switch or TI may have a different product that will work with a wider range ..
Edit: Oops... Actually, that requirement is only imposed when you need to do TRIAC dimming. Check out that design tool for a recommended layout with your specs.
03-17-2012 06:02 AM
Thank you for your reply.
But specifications which I have described here are final.
Can you please suggest me any other LED Drivers for my project?
Or can you please sugeest me any changes regarding the circuit?
Thanking You.
Jainam Shah.
