Multisim and Ultiboard
Flyback Converter Simulation Error
I've been trying to simulate the below circuit with the variation of values presented as well with several other varieties to see the effect on the output voltage. I built the circuit to step up the 9 V battery supply to 400 V. Every time I run the simulation it says Vo boosts to 100 V. Can some one explain why the value won't go above 100 V, and what I need to fix to get the output to simulate correctly. image.png
(2,818 Views)
Hi hhook94,
I am not familiar with flyback converter architectures, but I analyzed your circuit in Multisim. If I am not wrong, the stage in charge of increasing the voltage is between R3 and D2, right? Based on that I think that you can try using transistors with higher gain.
José
(2,766 Views)
