Multisim and Ultiboard
FFT Simulation in MultisimLive
Hello everyone!
I'm new in using MultisimLive and I've got a problem in simulating the FFT of some signal. Is there any way to do it?
(5,326 Views)
How about simulating a signal and calculating the FFT of it?
(5,299 Views)
Ok, but how can I do that? I searched for a Fourier Analysis in MultisimLive and I found nothing. As far as some sources that I read, in Multisim is quite easy to perform a Fourier Analysis, but MultisimLive seems to not have this utility.
By the way, I'm using MultisimLive because I'm working on Ubuntu, thus I can't install Multisim.
(5,291 Views)
Accepted by topic author 7Harrys7
Hi Harrys,
You are correct. There is no way to perform an FFT in Multisim Live, you'll have to either export the data and calculate in Excel or some other tool as Altenbach recommends or use Multisim (for desktop).
You can perform an AC Sweep which will give you a plot of magnitude vs frequency for a given circuit. This is not a breakdown of frequencies present in a signal but instead is a representation of how the circuit performs through a range of input frequencies.
Brian H. -- Electronics & Measurements Product Marketing Manager
(5,276 Views)
@I.B.Hating wrote:
Hi Harrys,
Thank you Brian! Well, I will try Multisim on a Windows environment.
(5,253 Views)
