Multisim and Ultiboard
Does worst case analysis work with model parameters?
The worst case analysis does not seem tow work with model parameters. I performed a worst case analysis on a simple one transistor amplifier stage. It gives correct answers for resistor tolerances, but for the transistor model parameters it never changes them. I did the same with a diode in the circuit and entered tolerances for the diode parameters and it never used the tolerances.
(3,468 Views)
I agree, this doesn't appear to be working in the simple test case I have created.  I keep receiving an error message:
    <model_name> <parameter> unchanged from <orig_value>
Can you attach your circuit?
Message Edited by NavyJay on 09-30-2008 08:40 PM
(3,456 Views)
That's the same message I get. See attached circuit.
(3,451 Views)
