Multisim and Ultiboard
Different pad diameter on copper layers
This my first topic here:
I would like to know how to change pad size with different diameter on each copper layer: 1.6mm on top and 2mm on bottom. Thank you for your help !
Yann
(3,764 Views)
As far as I know this is NOT possible.
Also, it is NOT possible to change the size of a component pad during the layout process.
Changes of component pads are possible with the footprint editor only.
It IS possible to use different shapes of the pads for top copper layer, bottom copper layer and inner layers, but diameter (or edge lenghts in case of square pads) is always the same for all copper layers.
All this refers to version 10 which we are using.
(3,724 Views)
I am using version 10.1 and it is perfectly possible to change a pad in the design without using the editor.
just right click on the pad or a selection of pads (SMT or TH) and change its properties.
You can also change it in the different layers, but beware,
check the preferences of your board manufacturer, they might not agree, especillay if annular rings on the inner layers get too small!
(3,719 Views)
I answered too fast, apparently you ca change shap and diameter of the combine top and bottom layer.
If you want the shapes to be different, it needs to be done in the editor
sorry for this..
(3,716 Views)
Thank for your replies.
I actually use the 11.0 version.
When I choose the properties of a pad or a group of pads I can select the layer but the values I enter in the pad size section modifies the size in all the layers at the same time.
Regarding the annular ring, is its value proportional to the diameter? What is the standard for most of manufacturers?
(3,697 Views)
oops I was way too fast with my answer. We are using two different layout systems and my statement refers to the other one. It is possible to change pad properties of components during the layout process with our version 10.0 as well.
(3,687 Views)
