04-06-2015 07:05 AM
04-07-2015 08:55 AM
Copper can be on the same side as components. There will be soldermask which is the clear material between the components and the copper to prevent shorts.
04-07-2015 11:07 AM
04-08-2015 07:23 AM
In case you have the copper on the same side (layer) as the components, your board must be manufactured as "double sided board". Oherwise, there will be no copper pads on the bottom side, and the through-holes will not be plated.
To avoid extra costs for manufacturing a double sided board, you can
- activate the bottom copper layer only when designing the board
- change the properties of each copper track you designed on the top (component) side so that they will appear on the bottom side. When selecting a copper track you can "select complete copper track" (re-translated from the german version), select "properties" - "position" and change the layer to "copper bottom".
BTW we have designed some boards intentionally with copper tracks on the component side only and only solder pads on the copper bottom side. But this is not usual.
