04-26-2013 03:50 PM
I'm new to Ultiboard, and I've placed two buried vias between the same two inner layers. How can I put a trace between them on of the inner layers?
Thanks!
04-29-2013
01:46 PM
- last edited on
10-22-2025
03:41 PM
by
Content Cleaner
Please have a look at the routing tutorial from the following to learn the different methods to route a trace in Ultiboard:
http://www.ni.com/white-paper/6880/en
I don't understand you question so you may have to elaborate. To route a trace from one via to another on the same layer, the procedure is as routing to two pads. However, if you want to route a trace from one layer to anther using a via, have a look at the following knowledge base:
http://digital.ni.com/public.nsf/allkb/7F94E89D05FEE01D86257A620065FE00
