Multisim and Ultiboard
Circuit with ECL components
I'm working with MultiSim 14.0 and have an old schematic with MC105 series devices that I want to build and simulate.
Has anybody worked with this scenario ?
(3,705 Views)
Hello anjames,
In this tutorial, you will find instructions to create custom components in Multisim. However, it is still not clear to me if you want to interface a real sensor or create the component for being used in Multisim.
José F.
(3,675 Views)
Jose,
Thanks for reply.
I want to use the ECL components in a  design file for simulation.
There are ECL libraries available in ORCAD. Can I import an entire library into MultiSim ?
Regards
(3,671 Views)
Hi anjames,
Unfortunately, Multisim is only compatible with Open EDA component library files.
Jose F.
(3,666 Views)
Jose,
Is there a document that details the Open EDA library file format ? Or does a tool exist that will convert .olb library files to .oecl library ?
Anjames
(3,638 Views)
Hello!
Navigate to ...<install directory>\National Instruments\Circuit Design Suite <version>\documentation\OECL Format Description.pdf. This document contains detail of the EDA component library.
I do not know if there is a tool to convert from one file format to the other one.
José F.
(3,632 Views)
