Multisim and Ultiboard
Can't find the node error
I'm trying to find the problem node in my circuit. But I have no idea how to read the error list that multisim gives me. Can someone help me? This is what I keep getting.
Instrument operation performed   (2009, May 21, Thursday, 19:58:20)
|   Instrument Analysis: Transient Analysis
|   |   Plot title:
|   |   Analysis settings
|   |   |   Initial Conditions: Zero initial conditions
|   |   |   Starting time (TSTART): 0
|   |   |   Stop time (TSTOP): 1e+030
|   |   |   Plotting increment (TSTEP): 0.001
|   |   |   Maximum time step (TMAX): 0.001
|   |   Perform consistency check
|   |   Variables from analysis
|   |   |   Show device values at the end of the simulation
|   |   Representation as SPICE commands
|   |   |   begin-scope page
|   |   |   checknodes 3
|   |   |   save all
|   |   |   iplot all
|   |   |   set reltol = 0.01
|   |   |   set trtol = 7
|   |   |   set itl4 = 100
|   |   |   set method = "gear"
|   |   |   set ramptime = 0
|   |   |   set convlimit
|   |   |   set rshunt = 1e+009
|   |   |   -param hrange 0 1e+030
|   |   |   save
|   |   |   tran  -env-options 0.001 1e+030 0 0.001 zero_ic
|   |   |   if-error end-scope audit-log-show
|   |   |   show all
|   |   |   showmod all
|   |   |   end-scope
|   |   Custom Analysis Options
|   |   |   Relative error tolerance: 0.01
|   |   |   Truncation error overestimation factor: 7
|   |   |   Upper transient iteration limit: 100
|   |   |   Integration method: gear
|   |   |   Transient analysis supply ramping time: 0
|   |   |   Enable convergence assistance for code models
|   |   |   Shunt resistance from analog nodes to ground: 1e+009
|   Output from instrument analysis
|   |   singular matrix:  check nodes adac1in:xu2.o0#branch_1_0 and adac1in:xu2.o0#branch_1_0 (How do I read this?)
|   |   TRAN:  Timestep too small; initial timepoint: trouble with (led_mod:xled1) d1:xled1
|   |   doAnalyses: timestep too small
|   |   tran simulation(s) aborted
(7,590 Views)
DawnLord0,
A singular matrix can arise for a few reasons - sometimes with floating nodes (internal to model or at circuit level) or with inductor components.   Is it possible to post the circuit in question?
This line refers to an instrument or component connection on U2 (adac1in is likely internal to the model) - usually a #branch is a SPICE designation to force/analyze current going through a node (SPICE tries to calculate the current/voltage at each node at each time step), thus the error is stating that the Multisim SPICE engine cannot correctly calculate this in this part of the SPICE netlist.  I believe you are getting several errors because SPICE tries to automatically change the time stepping (in an attempt to solve for a solution based on SPICE engine settings) and will eventually stop if unsuccessful.
If we can analyze the circuit, we'll have a better idea what is going on.
Patrick Noonan
Business Development Manager
National Instruments - Electronics Workbench Group
50 Market St. 1-A
S. Portland, ME 04106
Email: patrick.noonan@ni.com
Tel. (207) 892-9130
Fax. (207) 892-9508
(7,552 Views)
