Multisim and Ultiboard
Calculating trigonometric functions
Hi
sorry for my silly question but i am new in using multisim
i have a voltage or it can be considered as an angle.i want to calculate the sine & cosine of this angle to use the result as inputs to another circuit.
where can i calculate the trigonometric functions in the multisim?.
(3,783 Views)
Sounds like you need an ABM source.  If you angle is a voltage output, simply add an ABM for each trig function referencing your output.  Then change the "value" parameter to the following:  "sin(V(phase))"
You can find the ABM_VOLTAGE component in the Master Database under "Sources".
See here for more info on ABM usage.
-J
(3,768 Views)
