Multisim and Ultiboard
C interrupt vectoring
Hi there
I am struggling to get an interrupt to vector for me in the 8051 compiler in multisim simulation.
I have a simple external interrupt on EXTI0  set to edge triggered and enabled.
my isr is declared "interrupt void ext0isr (void) {...}" having read the hi-tech c51 manual this isr should be used whatever I call it.
yet the interrupt doesnt seem to vector at all other than the voltage change on the line to the INT0-bar pin there seems to be no indication that an interrupt has occured at all...
Have been scratching my head on this for months
The people over at Hi-Tech have been bought out and refuse to talk about anything not involving PICs
so any help much appreciated
(4,049 Views)
Hey Wolf
This may seem daft but have you placed anything in the interrupt to run when called. I dont know whats connected to your 8051 but maybe attach an LED to it and set the interrupt to light it for a reasonable length of time. At least this way we can verify if the interrupt is been called or not with that command.
Matthew Trott
National Instruments UK
www.ni.com/ask
(4,023 Views)
Hi Matthew,
🙂 yeah Ive basically got a simple keypad circuit set up with a 7-seg display for output of a pushed button.
I also had a breakpoint set at the first instuction inside the ISR.
The Hi-tech manual mentions two different methods:
1) Use the interrupt keyword on one function and all interrupts will vector to this ISR. This does not work as far as I can tell
2) Use the macros ROM_VECTOR() or RAM_VECTOR() that are in intrpt.h. intrpt.h has not been included in the Hi-tech installation (maybe its not in the lite version thats used in multisim?)
The manual however, Ive found, does give the equivalent asm code for the macro, so I can add this directly into my code using the #asm, #endasm directives....
	#asm
	GLOBAL _ext1isr// ISR name = ext1isr()
	PSECT vectors,ovrld
	ORG 0x34// Int vector
	LJMP _ext1isr// ISR function name again with a preceding underscore added.
	PSECT text
	#endasm
This works! (Though TBH I dont really know whats going on here)
But this is not dynamic, the variables in the asm portion are hardcoded eg ORG 0x34 instead of ORG vector_addr_var. I can circumvent this by moving variables to specific reigisters (like ACC) in the C preceding the asm and then referenceing those specific registers in the asm, however I have only been able to make this work for simple variables, pointers to functions Im having more trouble with, eg: LJUMP _intrIsrFuncName could be replaced with LJUMP ACC  where ACC is given the address of the function intsIsrFuncName()
I have had trouble trying to assign the address of the ISR to the pointer, using the code below:
int main (void) {
	void (*pisr)(void);
	pisr = &ext1isr;// Line 23
	ACC = ((int*)pisr);// Line 24
	#asm
	GLOBAL _ext1isr
	PSECT vectors,ovrld
	#endasm
	ACC = 0x34;
	#asm
	ORG ACC
	#endasm
	ACC = ((int*)pisr);// Line 33
	#asm
	LJMP _ext1isr
	PSECT text
	#endasm
 I receive one error:
Error: C:\Documents and Settings\tmole\My Documents\National Instruments\Circuit Design Suite 11.0\MCU Workspaces\8051_keypad\8051_keypad\main.c : 23 undefined identifier "ext1isr"
and three warnings:
Warning: C:\Documents and Settings\tmole\My Documents\National Instruments\Circuit Design Suite 11.0\MCU Workspaces\8051_keypad\8051_keypad\main.c : 23 illegal conversion between pointer types
Warning: C:\Documents and Settings\tmole\My Documents\National Instruments\Circuit Design Suite 11.0\MCU Workspaces\8051_keypad\8051_keypad\main.c : 24 illegal conversion of pointer to integer
Warning: C:\Documents and Settings\tmole\My Documents\National Instruments\Circuit Design Suite 11.0\MCU Workspaces\8051_keypad\8051_keypad\main.c : 33 illegal conversion of pointer to integer
Frankly void pointers to functions is outside my knowledge of C.
Any help much appreciated, would love to make this into a macro but again outside my level of knowledge.
(4,021 Views)
Ok In that last bit of code I think the issue is you need to pass the contents of the pointer instead of the pointer itself. I believe this is done using the '&' symbol. So on lines 23,24 and 33 you would put &pisr.
I would check the syntax of this on somewhere like http://www.cprogramming.com/reference/ as it has been a while since I have done any c programming.
Matthew Trott
www.ni.com/ask
(4,018 Views)
