08-16-2011 08:42 AM
HELP!
I'm not sure how I managed to do this, but when I go to vary the battery from 10 Volts to 12 Volts I cannot do it. The value field is "X" out and marked restricted.
What did I do?
Solved! Go to Solution.
08-17-2011 08:27 AM
Please help!
I have somehow managed to get the value field tab for all of the components set to "Restricted" Because of that none of the workbook examples can be used.
08-17-2011 10:59 AM
Hi Don,
I believe you have accidentally activated the circuit restrictions.
This can be disabled by going to Options > Circuit Restrictions and unchecking the Hide component values checkbox.
Jason
08-17-2011 02:03 PM
Jason,
That was it. However, when I first looked at that, the The "Hide Value" was unchecked. I then checked it, ran a test and then unchecked the box and it worked correctly.
Thank you!
09-26-2011 08:06 PM
Okay,
I did it again and now I get prompted for a password prior to being able to get to the circuit descriptions.
Two questions:
1) How am I accidently changing this setting?
2) I have entered a password for "Global Restrictions". But I never set up a password for "Circuit Restrictions".
It appears that I have accidentially found a method that selects a password for the "Circuit Restrictions" and then changes the properties of a Master Database component, "DCPOWER"
I do I fix my error and prevent it from happening again?
