Multisim and Ultiboard
BJT Area Factor discrepancy
I have created two BJT models using the database.  I am getting an unusual result when I am entering the area factors for the BJT model instances.
The two sub circuits do not give the same simulation results.  Which is the proper way for entering the area factor?  Note I have removed the .model details from the subcircuits for clarity.  The model I am using is posted below.
.SUBCKT PNP_8X 1 2 3
Q1 1 2 3  PNP1  8
.MODEL PNP1 PNP (.......)
.ENDS
Q1 1 2 3  PNP1  AREA = 8
.ENDS
.MODEL PNP1 PNP
+IS=2.6912E-18 BF=65.0 NF=1.000 VAF=52.0
+IKF= 1.350E-3 ISE=1.256E-15 NE=2.5 BR=4.0
+NR=1.0 VAR=3.0 IKR=1.35E-2 ISC=2.691E-17
+NC=1.00 RB=177.78 IRB=4.440E-4 RBM=13.33
+RE=33.75 RC=22.5 XTB=0.0 XTI=4.0
+EG=1.126 CJE=3.0E-14 VJE=0.928 MJE=0.333
+TF=1.990E-11 XTF=100.0 VTF=1.50 ITF=1.350E-3
+CJC=3.000E-14 VJC=0.732 MJC=0.45 XCJC=1.0
+FC=0.5 CJS=5.000E-15 VJS=0.655 MJS=0.0
+TR=1.990E-9 PTF=30.0 KF=1.0E-9 AF=2.0
+TNOM=25
(4,308 Views)
I have now come to the conclusion that the area factor parameter causes the PNP models to stop working entirely.  I am not able to get any sensible results when using the previously posted pnp subckts.  When using the NPN subckts I do get a working circuit but the area factor parameter is not consistent with the .model transistor behavior.  I am working on the assumption that an AREA = 1 is equivalent to the .model by it's self.
For instance, the methods below do not produce the same simulation results when entering these in the model section for a device in the database manager.
*Using only the model
.MODEL NPN1 NPN (.......)
THE BELOW SUBCKTs DO NOT GIVE THE SAME SIMULATION RESULTS AS THE .model METHOD
I assume the below methods are consistent but have not investigated this.
*Using a subckt
.SUBCKT NPN 1 2 3
Q1 1 2 3  NPN  1
.ENDS
*Using the AREA parameter tag
 .SUBCKT NPN 1 2 3
Q1 1 2 3  NPN  AREA = 1
.ENDS
 .SUBCKT NPN 1 2 3
Q1 1 2 3  NPN
+AREA = 1
.ENDS
(4,291 Views)
Hi Charkear,
What version of Multisim are you using?
Natasha Baker
R&D Engineer
Join the NI Circuit Design Community
Follow Multisim on Twitter!
(4,218 Views)
