Multisim and Ultiboard
AM using CA3080
I want to generare AM using CA3080 but i wont get the required wave. Is any wrong in my circuit
(3,491 Views)
I do not have Multisim, but looking at your .jpg image, I notice that either you are using an unusual convention or you have the power supplies wired backwards. Typically the positive power supply is connected to the upper terminal and the negative supply to the lower one on amplifiers.  You have it the other way.  Without pin numbers I cannot tell.
You are also running the CA3080 open loop.  Depending on the setting of the pot, the output may always be saturated or switching rapidly between one rail and the other.
Lynn
(3,470 Views)
The op-amps are flipped.  MS op-amp symbols have the non-inverting input above the inverting input.
(3,450 Views)
