Multisim and Ultiboard
ADVICE- equivalent circuit simulation/ design
Howdy,
Let me introduce myself. I am a research student, new with multisim. And I am looking at the possiblity of using multisim to simulate, initially an equivalnet circuit for a schottky diode. Modelling and fitting real world data to simulated data. With the rationale being that deviations from ideal diode(DC) I-V behaviour that have been observed in real world experimental IV characterisation can be understood and analysed/understood with respect to this simulation. These would likely include parasitic capacitances introducing, some time dependent RC circuits and interface effects. Could multisiim provide me the ability to do a parameter study on this? and similar effects?- The plan would be to cross examine through IV analysis. I am looking for a little hand in realising the potential of multisim in this area, and the approach that should be taken.
I have experimented with the DC oeprating point analysis, and parameter analysis and can see how some of the tools are there- but I'm really interested in creating an environment that will allow me to track these changes, dynamically through I-V representation.
Could someone perhaps provide me with a few pointers in realising this, and point me in the direction of an example that I could experiment with?
I am slightly hampered in circuit design from fundamentals.
many thanks and kind regards,
DC
(4,840 Views)
I suggest you look at the Arbitrary sources (also called ABM sources). They allow you to set a voltage or current output as a function of variables in the circuit and have support for a wide variety of functions and operators. They even supports Piece-Wise-Linear functions (using the table() function)
See Source>>CONTROLLED_CURRRENT_SOURCES>>ABM_CURRENT, Source>>CONTROLLED_VOLTAGE_SOURCES>>ABM_VOLTAGE. See their help file more info.
In the attached example you can see examples of a simple diode and an ideal capacitor which were created using the ABM_CURRENT sources.
Max
(4,819 Views)
thank you for the reply. I'll have an investigate further.
(4,800 Views)
