Multisim and Ultiboard
AD624 pinout incorrect in Master Database
It appears that the gain selection pins on the Analog Devices AD624 Instrumentation Amplifier are incorrect in the master database and d not agree with the data sheet. Review G=200 and G=500 and http://www.analog.com/static/imported-files/data_sheets/AD624.pdf. My component shows G=200 on pin 11 when it should be pin 12.
(4,609 Views)
Hi NewSciGuy,
Thank you for taking the time to report problems to us.
The screen shot shows what the symbol looks like in the current version 12.0.1, it looks correct to me.  There may haven been a problem with it in a previous version that was fixed.
You should be able to edit this component and resave it to your user or corporate database.  Place this part on the work area, double click on the it and select Edit component in DB.
Tien P.
(4,593 Views)
Thanks for checking into that. It must have changed in 12.0.1 because I placed the last one in the previous version.
(4,590 Views)
