Multisim and Ultiboard
74LS93 Mod-5 Problem
I've noticed a strange behavior when simulating a mod-5 counter using the 74LS93 or 74LS293 - instead of counting from 0 to 4, the counter displays 2 - 4 consistently. Other modulo numbers, e.g. mod-4 or mod-6 count correctly.
The problem disappears when I add a gate to the counter outputs, before connecting to the reset inputs.
I've attached a file with both circuits to illustrate the problem.
Does anyone know what is the cause of this problem? I suspect it is due to a timing issue. Is there a problem with the SPICE model for the component?
thanks,
steven
(6,493 Views)
13 years later...
One of my students just discovered the same thing. File is attached (this is for PLTW DE 3.2.3 proc 1).
The oscilloscope clearly shows channel B "clearing" to 1.
Being able to restart the count only at 0 is supposed to be a disadvantage of the 74LS93N.
(2,027 Views)
