Multisim and Ultiboard
1G Ohm multimeter reading with only 1k ohm resistence
I am a student just starting to use Mulitisim student edition 12.0 for very basic circuits.  My PC opetating system is windows XP.
First assignment went perfectly with a variety of series circuits using basic components - DC voltage source, resistors, ground, multimeter.
Started on my second set of assignments with parallel circuits yesterday.  Same very basic components.
Two problems -  first was a "no nodes" in circuit error when trying to run the simulation.  Surprising because as far as I know my steps to construction the circuit were the same as the previous assignment (just resistors in parallel rather than series).  This error went away after I relocated the voltage source.
Next problem, which continues,  - simulation results on multimeter show correct voltage 12V but 1G ohm and Amperage  " r"  out of the range.  I have checked the instrument setting and they seem ok.  No open point in the circuit detected or that I can see.
The only other piece of information I can think of that might help troubleshooting this is that my PC does show 100% CPU (2G, 2.1GHz) use quite often when running multisim.
(5,516 Views)
Accepted by topic author BBam
Can you post your circuit file?
(5,493 Views)
Thanks for replying, Tom. You get credit for solving this one.
When I went back to my circuit and looked at it after a couple days I spotted the problems.
First, was a branch with no resistance that I believe caused the "no nodes".  I put it back in green wire on
the attached circuit.  Second, was not removing the power supply when checking the resistance.
Kind of embarrasing errors even for a beginner.
Anyway, you prompted me to take go back to the file and discover the problem which I appreciate.
In the future I will set the problem aside for a while if I have that option and then,
make sure to attach the circuit if I post it looking for help.
Bill H
(5,464 Views)
