10-01-2007 02:18 PM
10-01-2007 02:47 PM
I have no idea on how long it may take them. I sent them another circuit about a month ago and haven't heard nothing from that yet. I don't work for NI, I am just a user with a good deal of experience with Multism and circut troubleshooting (my profession is Electronic Repair) that has volunteered to try and help on the forum when I can.
I hope they will not take long at least giving us their opinion on it. If it is a software issue, then we will have to wait until they decide to release any fixes to the software and I don't know when that will be. I have a post requesting any information as to the status of any updates, but it has not been answered yet.
I wish I could help more, but I don't have any more ideas or information.
Have A Nice Day
10-01-2007 05:06 PM
10-01-2007 05:44 PM
10-01-2007 06:44 PM
10-02-2007 08:44 AM
I was going to refrain from commenting on this again, but I will re-iterate what I think the 150V problem is. As it stands you have the RF coil tied into the output of the Bridge rectifier. It is my opinion that the RF is being feed into the Bridge, rectified, and added to the 12VDC that is already there. If you tie the RF Coil to the output of the regulator, then the all the voltages, excecpt for the AC voltage appears normal.
It may not be the RF as much as the EMF of the coil causing a high voltage at this point. Either way, if you move the tie point of the RF Coil that will disappear. There may be another alternative that Max has that we don't know about yet.
I hope this helps some. I still want to here Max's opinion on both situations.
Have A Nice Day
10-02-2007 11:01 AM
10-02-2007 12:29 PM
Thanks Max. That clears up the AC Voltage Situation that I was seeing. I really appreciate that.
Have A Nice Day.
10-02-2007 01:45 PM
I will make this my last comment on this circuit. I was going back and trying what Max said about not waiting long enough to view the AC Voltage and he was right. I failed to notice that the simulator time had slowed down after hooking up the timer. This is due to the higher frequency being produced by the timer. The higher the frequency the more time it takes to simulate a circuit.
While doing this I also checked about the 150V situation. If you set the simulator setting to set to zero, then this is not a problem. The voltage starts at zero and gradually builds up to near 13V and stays pretty much there. When I go back to Automatic determinination then it says 150V all the time. I thought this might be of some interest.
Anyway, I thank Max for pointing out my error and I hope some of this is helping.
Have A Nice Day.
