Name
Waveform Calculator
Included
LabVIEW Custom Instrument
Compatibility
Multisim 11.x, Multisim 12.x
Description
The waveform calculator can help you visualize signal modulation through arithmetic. The calculator has a separate viewing tab for signal analysis and the options to set smapling rate, size and interpolation method of the data. It will generate a resulting wave depending on your input expression and can take inputs of up to 4 different signals. Not only that, but it also functions as a regular calculator.
Instrument for Multisim 11 and 12 download
