Name
Triangle Signal
Included
LabVIEW Custom Instrument, Test Circuit
Compatibility
Multisim 11.x, Multisim 12.x
Description
The sawtooth wave is one of the most commonly used signal in electronic circuits, of which one of the most useful applications it essential in is as a component of a Pulse Width modulator (PWM). Paired up with the sawtooth wave you can have a combination of sounds very useful for audio application analysies and create thousands of sounds and harmonics for music synthesizers. You can find the Sawtooth Signal VI of the same design under the Sawtooth Waveform Generator document.
Instrument for Multisim 11 and 12.0 download
Instrument for Multisim 12.0.1 download
Test Circuit
The circuit here can be paired with that of the Sawtooth Signal VI from another document. Simply replace the Function generator with the appropriate VI to get much more complex sounds.
